I'm rebuilding a Marvel Schebler carb for an IH 444. Included in the kit is a new elbow with integrated filter screen.
Looks like this one:
https://imgur.com/abLurpc
My Dad took that off his tractor years ago and butchered up the fuel connection with some aftermarket fittings.
If I want to use the replacement elbow, I noticed it's not a standard inverted flare fitting.
From my research, I found that I need an IH tube nut part number 19985R1, looks like this:
https://imgur.com/IgQJymR
I have a tube flaring kit, but this tube nut looks rather special. Is the tube supposed to receive a bubble flare, or is there supposed to be a sealing o-ring or washer used with this setup? Some kind of special flare or flange on the end of the tube?
