Guy I know has a 1206. Low side of ta has been out for years. Hardly uses the tractor. Can hear a noise sounds like from the mcv valve. Kinda winding sound. Changes noise when turning the steering wheel. The tractor drives and steers fine at lower rpms. When you get half throttle or more it will stop moving. Dumped in an extra 5 gallons of hyd oil to rule out bad oring in the split section. Didnt help. Hoping it's just a blown gasket in mcv valve or bad pump. Do they act this way when the hi side is going out? Probably end up putting a ta in it anyways but want to figure out the problem first.
