bowhunternw
I started a topic about my battery boiling over. So I did bring a volt meter with me and it is throwing out 18 volts with a little engine speed. I did check the volts at the coil with the key turned on (not running) and it read 12 volts. That is where the voltage reg wire ties in and runs up to the hitachi altenator. The guy I bought it from is sending a new altenator incase the internal voltage regulator is bad. Is there something else that could be messing it up while running. The battery doesn't spark when I hook it up, so I don't think there is any strange draw.
