oil seal behind M break drum
bass
got to replace the oil seals behind the break drum on my M. are these seals above the trans oil? im going the drain the trans oil when I put in new pto seal and want to do the breaks at the same time.
bass
(quoted from post at 09:03:14 05/16/19) im going the drain the trans oil when I put in new pto seal and want to do the breaks at the same time.
bass
What are you asking?? If draining for the PTO it makes no difference???
For the brakes just park on a block if worried will not leak with a 4x6 or so under the wheel then switch no draining needed if for pto just park facing down hill.
