62Farmall560
New User
I have a 62 Farmall 560 that we had to replace an outer rear axle bearing and housing and shaft, so we drained the fluid from the body of the the tractor(which was very clean) removed the left rear housing bull gear and repaired and replaced everything. All was good except I now have no power steering to turn to the right turning left works so so. The rear hydrolics also whine now while raising and lowering. I filled the hydraulics reservoir until the fluid ran out of the fluid level plug on the left side of the tractor, with regular hydraulic oil is that the correct oil?
Thank you for your help
