Farmall & IHC Tractors Discussion Forum |
48 Super A - Hydraulics don t work
Author |
[Modern View] |
CapLoneStar
05-12-2019 22:14:57
Hydraulics worked two weeks ago when I bought the tractor. It turns out the hydraulics fluid was leaking into the crankcase oil so I did an oil change and replaced all the seals and gaskets in the hydraulic pump. I put two quarts of 30W oil into the hydraulic pump and started up the tractor. From what I can tell, I don t believe it is leaking anymore; so that s one problem solved. Long story short, now the hydraulics aren t working. When I push the throttle all the way up and adjust the touch controls, it sounds like it is trying to work. I ve rotated the rear bar, so I know it s not jambed. Air in the system? Not sure what the issue is now, thoughts?
CapLoneStar
05-14-2019 16:07:18
Re: 48 Super A - Hydraulics don t work in reply to CapLoneStar, 05-12-2019 22:14:57
[quote="CityBoy140"](reply to post at 11:07:43 05/14/19) [/quote
Found out it is 4 quarts. I have two quarts out of the four quarts in it, I m hoping the oil level is low enough when I open the panel nothing comes out.
CityBoy140
05-14-2019 07:07:43
I would guess so. I opened it after we drained the system.
CapLoneStar
05-14-2019 07:02:33
If I open it, is it going to drain all of my fluid out like the drain plug? And is it under pressure? I d hate to waste all the oil I put in.
CityBoy140
05-14-2019 03:18:50
Yes, that is the hydraulic filter. On my 140 I just rinsed it with some hydraulic fluid. My 140 is basically a newer version of the Super A.
CapLoneStar
05-13-2019 21:00:52
Delta, is this the panel you were talking about?
CapLoneStar
05-13-2019 19:09:52
Interesting. I was told 2 quarts and found it saying 2 quarts online. Where have you seen 6 quarts!
andymd
05-13-2019 18:55:23
I think the system holds 6 quarts
DeltaRed
05-13-2019 06:19:20
The throttle doesn't have to be wide open. An idle will suffice. Work the control back and forth 10 to 15 times. that should purge the air. If that doesn't work,there may be some crap in the internal valveing.The filter screen may also be plugged. It should be a flat plate about 2" square on the side. Has a small bolt on each corner.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
The Collection of a Lifetime - by Sherry Schaefer. The larest gathering of orphan tractors ever assembled by one collector will be auctioned off on May 15 in Rock Island, IL. Ed Spiess was a well known tractor buff who spent most of his time dreaming of rare and unknown tractors. His background as an agricultural engineer sparked his interest in the unique attributes of the models built from 1939-1959.
... [Read Article]
Latest Ad:
Need a clutch shaft for a 46 Massey Harris 101 Jr., F162 Continental engine. About 18.25 inches long, to fit 1-1/8x 10 spline clutch disk. Bare shaft without sprocket or bearing is OK.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
