Greeting,
I have 560Dwith an F-11 loader/bale grapple and a new problem.
When I push into a pile of hay or dirt the gear shift binds and I cannot get to neutral. I have had to pull the machine backwards an inch or 3 and that frees up the gear shift lever. It have never had this happen before yesterday. On a flat surface it shifts easily.
To model the behavior I can start up a steep rise/terrace. If I push the clutch in it stops and I cannot take it out of gear. If I drive on over terrace it shifts freely..
I have read that if the TA is not adjusted the clutches can bind the transmission. I have tried adjusting the ta but to no effect so far. I did have ta action before the adjustment but now nothing. I adjusted the long and short linkages for 1/8 inch of travell. I found this in a video of adjusting the ta for a 300
What should I try next
