M break drum oil seal
bass
do any of yall know the part number for the seal behind the break drum on an M?
I need to replace the old seals but cant find the part number for them.
bass
See if this isn't the one you need. Check your serial number against the ones listed.
https://www.yesterdaystractors.com/Farmall-M_Bull-Pinion-Shaft-Bearing-Retainer-Oil-Seal_VT3755.html
Also the new replacement seals aren't nearly as thick as the originals and some people put two newer style ones in there in place of the old one. Your old brake drum may also have a groove in it and with two seals you stand a better chance of it actually sealing. I put two on each side in my H when I replaced those seals and no more leaks since.
