CapLoneStar
Just bought a new 12v battery, I ll be needing to disconnect the battery and put the new one on. It s simple enough to do but I m confused because the battery is positive grounded and it s staying positive grounded with the new battery. This system on my Super a is a 6volt. (Not sure if that affects it)
So do I disconnect the positive (ground) first? Then the negative (live)?
And when I reconnect the new battery do I put the negative (live) on first then the positive (ground?)
Thanks in advance
Thanks in advance
