Tried starting my 100 after sitting over the winter and I have no spark. Its a 6 volt system and I only have 3-4 volts at the coil. I thought maybe the wire to the coil was the problem as there were some bare
spots on it but it didn't change anything. Shouldn't I have 6 volts at the coil or is there that much voltage lost normally. I get 6 volts on the battery and it turns over the engine real well for a 6 volt
system. I'm measuring voltage without cranking the motor.
