Distributor
robertw
I was wondering if any one out there knows the part number on the distributor that goes into a farmall 300 row crop tractor and is the 350 row crop distributor the same with the advance at 22 degrees?
Thanks for any help
Robertw
Unless you run across a new one with a part number the only way to tell what was original is to look at the distributor code on used. At the round part of the housing where the two clamps retain the main distributor housing you will find a code stamped in. First letter indicates use. Early 300 gasoline used a O code letter and the other gasoline including 350 used a S code letter. Think the only difference in a O and S was the springs used. You can see a little bit of code letters in this housing. Larger numbers above is only for the housings and most all tractors of that era have that number housing.
