Fuel for a F14
Charlie M
Just wondering what fuel people who have F12/F14 tractors are using. I understand the diaphragm in the fuel pump isn't ethanol friendly and I think that is what is wrong with mine since it won't start this spring and was getting hard to start last year before I put it up for the winter. Should I be using non ethanol gas?
I use non-ethanol gas in my old tractors that might sit for months before I can use it up. Regular gas seems to keep longer and with a bit of Stabil they can sit much longer. I use ethanol gas in my two tractors that I know it will get used up in a reasonable time. Both old, both pre ethanol, never hurts them a bit.
When my F12's diaphragm went out it leaked fuel everywhere, I rebuilt it with a deluxe kit with a pre mounted diaphragm and found my pushrod was worn short, replaced it with a parts one I had that was 3/16" longer, made a huge difference.
where do u buy these diaphrams? I been searching all over for a w9 fuel pump or diaphragm.
Rusted, have couple places you might have luck with. Rice Equipment INC(Clarion Pennsylvania) has diaphragms for the F12/14. Maybe make one for the W9?. They don't list a pump or diaphragm for the 9, but website says to call if don't see it. Other place I would try, is Then & Now Automotive(Weymouth Massachusetts). I have used them for IH truck fuel pumps, L R S models. Might be worth a call phone call, worst they could say is no.
(quoted from post at 21:44:49 05/08/19) where do u buy these diaphrams? I been searching all over for a w9 fuel pump or diaphragm.
You can buy one right on this site, look up F12 fuel system parts and the W9 is listed on the fuel pump kits. I got mine from thefordsonhousefor $20 less
