Company Logo Shop Now
Re: Voltage Regulator
Bob/Maine
04-04-2001 06:01:44
Thanks! I will give it a try and get back with you. Bob
Bob M
04-04-2001 08:45:22
 Re: Re: Voltage Regulator in reply to Bob/Maine, 04-04-2001 06:01:44
Bob - Before you try adjusting the relay spring tension, make sure there's a good solid ground connection between the regulator base and the tractor frame. A poor regulator ground can cause exactly the charging problem you describe.
Also if you do wind up reducing the relay spring tension, make sure the relay drops (the contacts open back up) when the engine stops. If the relay doesn't drop when the engine stops it'll run the battery down real quick. ...Bob M
Bob
04-04-2001 09:02:49
 Re: Re: Re: Voltage Regulator in reply to Bob M, 04-04-2001 08:45:22
Hi Bob M: Thanks! I will look for the problem and get back with you on how I made out.
Bob
Today's Featured Article - Product Review: Electronic Ignition - by Staff. Oil, for example has come a long way in the last 50 years and I don't use anything but the latest API grade available. I've heard the arguments for non-detergent oils but would never trade it for today's formulations. Paint is another, the modern acrylic enamels are great for resistance to grease and fuel stains, retaining their shine and they last forever; unlike enamels and lacquers . Still another is the alternator. No doubt using the original generator keeps the tractor pure, but for thos ... [Read Article]
Latest Ad: 1953 Ford Jubilee SN#70068. I can provide pictures upon request and please only serious inquiries for the tractor. This tractor has been well kept under a shed. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
