1256 brakes
DeltaRed
The left brake has developed a substantial 'delay'.The brake will not engage for several seconds. I have to step on the pedal anywhere from 50 to 100 ft from the end of field.When it does engage,the brake is good. It holds,letting me turn.what could be causeing this delay?The brakes have never been perfect,they chatter sometimes.But they always worked.The right one still works,but seems to be fadeing.Steve
Bet you have and adjuster problem and lots of brake dust build up , also check the headed pins on the brake pedal and the linkage at the valve for any binding
