Order Farmall Cub Parts Online
farmall cub exhaust manifold color
rob in nh
05-05-2019 19:13:53
What color would you recommend for the exhaust manifold, tractor color or a grey high heat paint?
rustyfarmall
05-06-2019 08:01:03
 Re: farmall cub exhaust manifold color in reply to rob in nh, 05-05-2019 19:13:53
That would be correct. The manifold would have received some red paint at the factory, as the rest of the tractor was being painted.
rob in nh
05-06-2019 07:07:12
I've painted with east woods high heat before, did burn off after a while. This one i'm restoring to original so i may paint it tractor color. thanks for the replies.
Bob
05-05-2019 22:00:20
NOT sure what "look" you are trying to achieve?
When it left the factory the exhaust manifold was painted with the same basic (cheap?) IH red paint the rest of tractor was painted with, and the paint on the exhaust manifold quickly burned off when placed into service/under load, leaving a pretty much bare cast iron manifold that soon developed a rusty "patina".
Are you looking to somehow improve upon that?
What do the "correct police" desire?
Dave H (MI)
05-05-2019 19:31:59
I used black BBQ paint on mine. Looks pretty good.
Janicholson
05-05-2019 19:16:49
Unless you have it ceramic coated, it will be red and rusty brown is an hour. No paint will work no matter what the can says. Jim
