CDellaLucia
New User
First and foremost I have to apologise for my incompetence. This was my grandfather's tractor. There issue is the ram that controls the fast hitch will only go up when someone helps it. It will go down. As for the touch controls it will tilt forward and backward but not really side to side. My father and I have replaced the pump and also all of the gaskets and o rings inside the hydraulic block I guess you would call it. But still the same problem. My dad thinks that we overheated the system last summer while using the sickle mower. We found out the temperature gauge wasn't working and thought maybe she overheated. We replaced the temp gauge just so you know. Any advice would be greatly appreciated.
