Hello,
1940 Farmall A----I have antifreeze in my oil. I tried using the tablets in the radiator and it didn't improve. I dropped the pan and didn't see any antifreeze on the cam shaft nor do I have a loss of power or bubbles in the radiator. I am guessing it is from an O ring seal around one of the sleeves. My next action will be to drop the pan again and pressurize the radiator to see where it is leaking from. If it is a sleeve, is there an easier way to change it or do I have to pull the piston and then the sleeve?
