Hey all. My woes continue with the ole girl. After the Bull Pinion Seal replacement, I noticed my left axle had a drip (I replaced both axle seals, due to pulling the axles). I was hoping it might heal itself once it got moving. However, I've only moved it in and out of the shop a few times, and used it to unload a mower off a trailer. The leak has gotten significantly worse, to the tune of a 2 ft wide puddle that reaches to the front of the tractor. Any suggestions or magic potions out there to try before I go in and replace the seal again? Is there a better source than another for these seals?
