farmall450
New User
I posted awhile ago about this and finally
got the tractor split. I found a wore out
pilot bushing letting the input shaft
wobble around. The clutch disc and pressure
plate are new. My question is on the
throwout carrier. It has the newer style
with the replaceable bearing. Where does
the throwout carrier sleeve go that the
carrier rides on? Is it pressed into the TO
bearing carrier and if so how does it get
lube? If I buy a new carrier does it come
with the sleeve?
with the sleeve?
