656 and 756 grill
Not sure,but I doubt it. 756 is taller.But ,I do know an 806 grill will set right on a 1456 just like it was made for it.Because my '14' has an 806 grill.
Nope, they're the same size. Reason I know is because I have a 756 grille installed on an old-style 656. All we had to do was drill the two holes in the cast shell at the top for the spring pins, and it popped right in like it belonged there. Even the bottom pins lined right up.
A 756 hood is lower than the 8-14 tractors. In fact the cast grille/radiator shell is the same part number as I recall.
The difference is the 656 has MORE horizontal bars than the 756.
