706 Wire loom
Binder man
New User
I am thinking of making a new wire loom for my 706. I have a wiring diagram and it seems pretty simple. What I am after is the 10-12 wire (I have not counted) connectors that connect the front, rear and LH & RH Dash all together. I don't know where to get these. I know most of the connections are Packard or what ever. Does anyone know where I could come up with the multi-wire connections at? I thought about using something different such as molex. What do you all think???
Well f the org plug in is in good shape reuse it the Delco end come out easy if you make a TOOL to release the lock tab . That tool is easy to make select a cotter pin that one half of it is as wide as the slot in the connector , take the other half and bend it out at 90 degrees as sort of a finger stop then file down the long side flat with ssomewhat a sharp tip so it will slide down the release slot then ya just insert the tool down the slot push the wire end forward and shove then pull the wire end and wire out. I use a cotter pin about 2 inches long for making up the tool as i9t seams i keep misplacing the old ones from time to time . If i was more computer smart i would post a drawing of this home made tool. Years back every tool truck had the made up tool on them , now all the seam to carry is the tool for the modern day ends . You will need light blue dark blue , light green dark green, black , purple red , white,orange , yellow and maybe pink for colors in 16-14 12 and 8 ga. Oh yea Gray for got about the gray. loom ya can get from Terminal Supply along with some new connectors . The connectors are the black ones , do not use the clear . You can also find them on older GM cars and trucks along with older I H trucks . Most of my supply came from a junk yard fro cars and trucks going to the crusher . A pair of side cutters and a day of rummaging i filled two large boxes of end and the price was wright FREE.
