Company Logo Shop Now
IH 444 Leaking Axle Seal
Kerplooey
04-29-2019 20:17:43
Hey all. My woes continue with the ole girl. After the Bull Pinion Seal replacement, I noticed my left axle had a drip (I replaced both axle seals, due to pulling the axles). I was hoping it might heal itself once it got moving. However, I've only moved it in and out of the shop a few times, and used it to unload a mower off a trailer. The leak has gotten significantly worse, to the tune of a 2 ft wide puddle that reaches to the front of the tractor. Any suggestions or magic potions out there to try before I go in and replace the seal again? Is there a better source than another for these seals?
Kerplooey
05-02-2019 17:35:09
 Re: IH 444 Leaking Axle Seal in reply to Kerplooey, 04-29-2019 20:17:43
It does make sense that is what happened, being it started slowly and got progressively worse. I won't mention to my buddy that I doubted his work. Lol
used red mn
05-02-2019 16:50:41
I donít know if the seal for this application has a spring in it to help compress the sealing lip. If so it is possible that the spring was dislodged from its proper location during installation. If this happens it can be pulled back in place before assembly with a ...Coon prick awl... or in a pinch a piece of bale wire or 12 or 14 gauge solid copper wire. Bend a 1/8 to 3/16Ē 90 degree hook on the end. To prevent this I smear globs of grease about 4 places around the seal to hold the spring in place while it is driven in its bore.
Kerplooey
04-30-2019 05:06:43
I'm guessing that it was an installation issue. It didn't leak before. I was gentle as could be sliding the axle in, but I didn't personally press the seals into the carriers. Ugh.
BarnyardEngineering
04-30-2019 04:20:36
It's likely not the seal that is the problem. It is either the shaft, or the installation method.
When the shaft has a badly worn groove where the seal rides, no seal will hold. When you (unintentionally) wreck the seal during installation, it will leak.
No magic fix. Axle has to come back out and another seal installed.
Today's Featured Article - ... [Read Article]
Latest Ad: Front hydraulic pump for loader .. drives off tractor front. Mount bracket included. Greisen brand which is my favorite brand for hydraulic controls. This is use some, then removed and stored inside for several years. Can ship send along your zip for rate. thanks [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
Binary file (standard input) matches
