warren woodrow
My 424 runs great pulling a plow for about 25 minutes . It then start missing under load as if it is flooding. I can raise the plow and it usually seems to " clear " the flooding or stop sputtering. So far I have eliminated : clogged gas cap vent, distributor timing . Beginning to believe it is my coil but was wondering if anyone has any other ideas about things to check before I start changing parts . Would a bad condenser allow it to run great for 25 minutes and then start sputtering or flooding ? The condenser and points probably have less than 20 hours on them . I did install a new aftermarket distributor several months ago which solved problem caused by slop in the old distributor shaft .
