Farmall & IHC Tractors Discussion Forum |
MW governor adjustment?
Author |
[Modern View] |
graveldog25
04-26-2019 16:27:58
Hello all! I recently purchased an MB power grader with the Farmall M as the power plant. The engine has an M&W governor on it. The throttle shaft tube was broken where it bolts to the carb. I got a different tube with the throttle shaft in it. Is there any adjustment I need to make after I install the other shaft I’m going to put on? I know on the original style governor, the little clevis should be threaded up or down so the pin goes in without binding so the governor link and the throttle shaft are in synch. Is there a procedure like that for the M&W governor?
pete 23
04-26-2019 20:34:28
Re: MW governor adjustment? in reply to graveldog25, 04-26-2019 16:27:58
Same procedure on M & W governor as IH. Pull throttle wide open, full speed, pull up on linkage going to carburetor and adjust the link coming up from below so it just fits freely together. Has a ball socket type end , rather than a headed pin but same adjustment . The idea is so that when weights are fully collapsed from spring pressure, throttle butterfly will be fully open. Too short and it won't open butterfly fully and too long will cause unnecessary slamming of throttle against stop in carb causing premature wear.
graveldog25
04-27-2019 11:35:34
Re: MW governor adjustment? in reply to pete 23, 04-26-2019 20:34:28
Thanks for the info pete 23!! Much appreciated!!
graveldog25
04-27-2019 08:48:06
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor.
... [Read Article]
Latest Ad:
JENSEN miniature pump jack. 13W. Operating smoothly. 5 weights.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
