international 300 Steering leak
newhaven
my 300 Utility has developed a power steering leak... seems to be coming from the steering column cant see it where it coming from..is there a common place they leak?? my be able to see if I remove the starter
There is an upper and lower seal in the column. There is a vent tube and hose (maybe hose) on the right side of the column under the dash. Replacing the seals
by tearing it down is necessary. A repair manual is necessary. Jim
(quoted from post at 10:16:15 04/26/19) There is an upper and lower seal in the column. There is a vent tube and hose (maybe hose) on the right side of the column under the dash. Replacing the seals
how big of a job is that..
Guessing, as I have no way of judging your skill/tools/shop, with all going well and some experience 10 hours. Jim
On my 350U there is a pipe plug near the top of column with a small hole that acts as a vent. Dealer said to drill the small hole bigger and attach a nipple and run a hose back to the reservoir. That might work till you have time to tear it down properly.
