MD choke rod.
lbg57
Would it be possible for someone to post a couple of pictures of what your choke rod looks like on your Farmall MD?The one on ours is so bent/cobbled/welded that I would like to see a correct one so maybe I can fab a new one. The parts book lists 2 different lengths, 46 5/8" long & 45 27/32". Any idea as to the different lengths? Thanks.
I can send a picture to a ph. #. I measured and sent out my W400 sheet metal around clutch and brakes and under dash to a guy and he did a really good job on the fabrication just from my measurements and pictures.
Don't have a picture but those length are not for a diesel. Diesel also used at least two depending if tractor came with a voltage regulator mounted on the rear fuel tank support or not. Light and start attachment with regulator at tank support probably started during 1950.
