I bought a 53 Super M last fall, didn't run, had an issue or two (1 bad rear tire and rusted out gas tank) but the price was just to good to pass up - had a factory wide front to boot. Got it going yesterday and it runs excellent. I went to check the steering (tractor was not moving) right turn was fine (so far) but left or counterclockwise on the steering wheel made a squalling noise with the hoses jerking. I'm thinking (hoping) the power steering fluid is low and that's the reason for the noise, etc. I am not sure how or where to see if the fluid level is correct - or if you can. Iv'e never owned a Farmall with power steering but had several straight H's and M's in the years past. My question is: What is the first thing to check or look for with this issue. The pump appears to have no fill level or check plug from what I see.It's much easier to ask someone who knows like some of you. Thanks.
