farmall pete
Was loading manure with the farmall 504 today when the lower bolt that holds the remote valve stack together broke, spraying fluid all over. I took the stack apart and replaced the bolt. It was a grade 8 bolt, so I was surprised it would break in that situation. Put everything back together.
Now the remotes are acting funny. The levers are very hard to push and pull, and the hydraulic pump sounds like it's laboring more than usual. It has dual remotes and both are acting exactly the same.
This really screwed up my plans for the day. I took the spool out of one of the remotes, but could see nothing wrong. Is my problem up the line someplace? It would seem so since both remotes were working fine, and now neither works right.
Ideas would be appreciated...would like to take advantage of today's nice weather!
