YooperJD60
My Super C has been sitting for about a month without being ran. It was nice weather out so I wanted to pull the oil pan to inspect the oil pump. When I removed the drain plug,instantly I saw about a cup of antifreeze pour out! So I continued to remove the pan and oil pump..after the pump was removed I noticed antifreeze drip on the crankshaft...Looking up from the bottom I could watch antifreeze drip from the # 4 cylinder sleeve....It looked like the piston was up in the bore about 1/2 way and it appeared to drip from the inside of the sleeve. I'm thinking a leaking head gasket...I'm going to borrow the cooling system pressure tester from work and next weekend I'll pump it up and watch again. I hope it's NOT leaking from the sleeve o-ring!!
