Funtwohunt
I have an IH 806 with a Roosa Master pump. It has been setting inside a building with fuel shutoff since 10/18. Started it this morning and it started a pretty good leak, actually a small stream, out of the bottom of the large nut that has the adjustable bolt and nut in it at the bottom part of injector pump. Never leaked prior today. Sorry I don't know what it's called. See photo. I tried to tighten it a bit but still leaked. So I loosened it up a 1/4 turn then retightened, still leaks. I thought I would screw it out and see what it was but it screws several turns freely then seems to start to bind up. So I screwed it back in and figured I would ask you YT'rs for help. Is it something I can screw out and replace an O ring or gasket. Or is there some behind it that will mess up the pump if I remove it? Any Ideas would be welcome. Thanks funtwohunt
