Case IH 3220 Injection Pump
jeffersontwp
New User
Recently had the injector pumps rebuilt and found they contained water. Removed all fuel, replaced filters, etc. Still not wanting to run. Noticed a leak on the
injector pump and was wondering if a bad gasket could be the problem. Can just the gasket be replaced or would the pump need to be removed.
Some Bosch VE pumps use O rings on the advance piston caps, later some use an embossed gasket. If your sure that's where the leak is either could be replaced without calibration re-check.
