Farmall & IHC Tractors Discussion Forum |
706 gas starting
Author |
[Modern View] |
Cmore
04-17-2019 18:36:54
I have new battery good cables, but my 706 gas will about 1/2 the time only start if I jump across solonid with screwdriver. Can a bad rubber starter button be the cause of this? Can starter button be replaced from the outside of dash without removing cowl?
The tractor vet
04-18-2019 09:55:05
Re: 706 gas starting in reply to Cmore, 04-17-2019 18:36:54
706 Gasser starting problems, Well First off on replacing the starter button with out pulling the dash . IF you arm and wrist will bend in four places and you hand is missing two fingers and vary small then it can be done , so no if you are normal ya have to pull the dash . First place i look is the clutch safety switch located under the floor or deck plate on the left side if it still has one and some one did not twist the wires together or put in a but splice that has worked loose or corrosion . That wire will be and orange wire that comes down from the starter button to the safety switch then on to the starter . The next place to look is under the dash cowl as there is a multiple wire connection that is also in the mix and some times they get corrosion at that point and all power stops there , you have to remove the T/A lever and hand rails to lift the cowl to gain access. again you looking for the ORANGE wire.
Janicholson
04-17-2019 19:08:40
It can cause the issue It could also be the wire connecting it to voltage, and or the wire to the c=solenoid. I think the panel needs to be opened to gt to the switch. Disconnect the battery when working on it to avoid letting smoke out of some important device. Jim
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor.
... [Read Article]
Latest Ad:
JENSEN miniature pump jack. 13W. Operating smoothly. 5 weights.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
