Company Logo Shop Now
TractorLinks.com
Clutch not releasing.
5 Forward
04-15-2019 16:00:30
I have mid 80's 255 case international diesel tractor. I was having problems with the clutch releasing, so I replaced the pressure plate, disc, and throw out bearing. There was no oil on the flywheel, so just scuff up the surface cleaned it and put it all back together. now I am still having problems with the clutch releasing. I have checked the linkage more than once. Any ideas of the cause or what am I missing?
BarnyardEngineering
04-16-2019 04:19:07
 Re: Clutch not releasing. in reply to 5 Forward, 04-15-2019 16:00:30
What are the "problems with the clutch releasing," specifically?
Examples: Push the pedal and tractor doesn't stop. Push the pedal and gears grind when trying to shift, but tractor does stop when it is in gear. etc.
5 Forward
04-16-2019 08:25:34
 Re: Clutch not releasing. in reply to BarnyardEngineering, 04-16-2019 04:19:07
The gears grinding. Start in neutral can not get in gear with the clutch disengaged. The transmission seems to be turning with the clutch engaged or disengaged.
cole in mo.
04-15-2019 17:02:57
You didn't say anything about replacing the pilot bearing, if it fits just a little too tight, it will turn the input shaft keeping you from getting into gear.
5 Forward
04-16-2019 02:57:02
 Re: Clutch not releasing. in reply to cole in mo., 04-15-2019 17:02:57
I did replace the pilot bearing.
cole in mo.
04-16-2019 16:43:19
 Re: Clutch not releasing. in reply to 5 Forward, 04-16-2019 02:57:02
If you've got the right throw out bearing to pressure plate fingers distance, and the pilot bearing isn't binding, perhaps you got the disk in backwards.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
