3050 Int loader question
marlin54
I bought a loader and got it home and found out it is the same loader as my 3050 I have on my 2500A backhoe. So was was wondering what other Int agriculture or utility tractors will it fit on ? How does it compare to the 2000 series Int loaders ? thanks
It will fit on whatever you want it to fit on, really. Depends on how much work you want to do.
What tractor did it come off of? Did you get the brackets for that tractor? If so it will easily fit on that tractor and probably most others in that series. In addition it may fit other tractors that were based on that series. For example if it came off a 574 it will fit most of the 75 sereis, and probably the 84 series, 85 series, and 95 series.
