THANKS-Jerry,Rick,FC,Dave,Phlogiston,Norm,HAAS,Bill,CNRED
Martin Kellner
04-02-2001 11:09:19
Thanks for all of the advice on the tranny oil. It worked very well, clumps of junk came out when I opened the plug. I guess I put more kerosene in than I should have. About the last half mile of my ride (3.5 miles) some oil began to run out of the base of the gear shift stick (about half a cup). Do you think that I damaged a seal or anything? I really appreciate all of y'all's help.
Rick
04-02-2001 17:59:41
 Re: THANKS-Jerry,Rick,FC,Dave,Phlogiston,Norm,HAAS,Bill,CNRED in reply to Martin Kellner, 04-02-2001 11:09:19
No prob...you got the kerosene out and the good stuff in, Right? You have done your tractor a world of good...not to mention your conscience
Haas
04-02-2001 12:52:30
I suppose if you hit some rough spots, the thin kerosine could slosh and come out around the gear shift. Nothing there to stop it from coming out except gravity.
Phlogiston
04-02-2001 12:28:07
I doubt you hurt anything. Did you use the kero flush more than one time? As long as you have the proper amount of Hy-Tran in there now, I wouldn't worry about the little bit you had coming out the shifer if you had it over-filled. I must say, I have never heard of it coming out of there before.
