Injection pump shop
IA1456
What are people recommending for Diesel Injection and nozzle work in Northeast Iowa just wondering where everybody's taking stuff
My brother owns a business that does pumps and injectors. You can check it out at lukkendiesel.com. He is primarily a Cumins man but he can also do Roosa master and Model 100 pumps and probably a few others. He is located in northeast Nebraska but people ship him pumps from all over the US.
I still work on older pumps, Stanadyne-Roosa-Master, CAV-Lucas-Delphi, AMBAC M100, Bosch VA, VE rotary, some inlines, Simms, JD twin pumps and injectors, Cummins PT, Disesl-Kiki-Zexel, Nippondenso pumps are what I see most..
well i been using spencer diesel for around 20 25 years now great people good product call them up tell what i need thy put box ship it to me i put the return in same box ship it back i had one pump that was not right thy took care of it there the only place i ues for pump turbos injectors
I use spencer diesel and Midwest fuel linjection. I do most my business with spencer diesel, they have quick turn around time and a lot of knowledge.
Your close to Ed gruenther at heritage diesel. In Illinois. He did my 560 pump. And check Ed my injectors . I live in Ohio ,I sent to him cause I wanted someone that works on ihc. I felt it was worth it so I didn?t have any issues.
Depending on where you live in Ohio i take all my pump work over to New Castle Pa . to Progressive diesel . Harry was and old I H mechanic and he does the R D pumps for me .
I had dieseltech rebuild the pump for my 886 a couple of years back. It was a week to the day from when I put it in the mail to when it returned. It was inexpensive and perfectly done. That tractor fired right up with the timing directions he emailed me and it runs like a top. I can?t recommend him enough.
