656 IH / Farmall
There a lot of cabs you could put on a 656.Finding a cab specificly for a 656 would be harder to find. Find a cab from a 706/806,etc, It would be fairly easy to modify the mounts. A 656 is a smaller framed tractor,I've seen few 656 with cabs,yet thousands of 706/806 with cab.YearAround,hiniker,Cosy,Ansel...any popular cab would be a candidate. If you are handy,make something fit. I have put a cab from a 9000 ford on an 856. I still own a 706 with an Ansel 'Ace of Diamonds' cab from an 1130 massey. Just had to make mounts and tin work.Find a sutible cab,and post back.
[b
I guess I should rephrase my question . My concern is if the actual cab dimensions have to be changed or if it would be just addressing cab mount changes because of narrower frame ?[/b]
The front mounts will most likely be changed some. The tin around the front and rear may need to be modified a bit too. But structurally,everything shoud be fine.So a cab from a 706 will require the least modifying. An 806 is taller in front,but should cause no real issues.
