farmall cub hydraulic pum p
khouse6
tore down a farmall cub hydraulic pump. was surprised to find a seal with rectangular cross section and not an o ring. put the o ring inside and , i decided it was too much. was there a pump that did not have an o ring ?
(quoted from post at 20:02:55 03/15/19) tore down a farmall cub hydraulic pump. was surprised to find a seal with rectangular cross section and not an o ring. put the o ring inside and , i decided it was too much. was there a pump that did not have an o ring ?
yes sir ken there were two different styles my 58 has the o ring just replaced it last week
The earlier pumps had the seals. If you have a NAPA in your area their number is 5068. IH part number is 35507420R91. Most any auto parts store should be able to cross it over. The new seal will be considerably thinner than the old one, which will allow you to seat it where it does NOT ride in the groove the old one created.
thanks john I went to find that number and then got side tracked lol are you the one who tried those viton o rings ?
