I am in the process of finishing up a complete overhaul of my transmission in my SMD. I replaced all bearings, seals and several gears including all of the slider gears. I replaced the poppets and springs for the forks and didn't see any issues with the forks. I carefully put the operator platform on the trans today and hear a scraping sound as I was turning the bull pinion shaft with all of the sliders in neutral. It scrapes for maybe 60 degrees of each revolution at the same spot. I think it is a fork rubbing on one of the slider gears. There was no noise before I put the deck on today. I don't think it is 4/5. Is this an issue or will it harmlessly wear in?
Thanks,
Dan
Thanks,
Dan
