I am in the process of completely rebuilding the Farmall Super A. Replacing nearly all bearings and seals. I just put the PTO assembly back on and put the Transmission cover and shifter back on. Which reminded me that I seem to have s constant problem of water getting in the transmission. On the gear shift there is a sheet metal cover that goes over the area where the shifter arm goes into the transmission. On top of that is a spring with a cup washer that is held in place by a pin through the shifter lever.
The cup washer appears to be upside down as it would appear to act as a funnel for water rather than shedding water.
Unfortunately the gear shift knob is JB Welded in place.
So suggestions for keeping water out of transmission?
Any other place it could be getting in.
Are there rubber boots that are available for this?
