Company Logo Shop Now
TractorLinks.com
farmall 300 hydraulic
Larry Jensen
03-13-2019 15:47:00
I am putting a hydraulic system back together on a Farmall 300 and was wondering if there is a way to prime the pump as the lines are well above the fill plug on the reservoir tank
rdandersom
03-22-2019 22:58:50
 Re: farmall 300 hydraulic in reply to Larry Jensen, 03-13-2019 15:47:00
When I split mine for a clutch I undid the block on the bottom of the pump from the pump itself. It pumped fine without priming when I put it back together.
sde
03-13-2019 20:55:10
On my 400, there is a plug at about 10 o'clock on the housing that can be removed and you can add oil in the hole to prime the pump. It is the pressure relief valve and if you remove the spring and the ball, it will take oil. The plug is threaded in to a curved section of the housing, and getting the plug started straight is critical.
gene bender
03-13-2019 18:31:19
Just put some oil in the pump before you attach the lines
FastFarmall
03-13-2019 15:55:07
Where is your tank located, if it's a factory tank,i think it will pick up on it's own, if the tank has been relocated you can try a rag and a blow gun in the filler hole, but you might need some one there to help you, while you start the engine.
Larry Jensen
03-13-2019 16:00:32
 Re: farmall 300 hydraulic in reply to FastFarmall, 03-13-2019 15:55:07
Factory tank right below steering wheel
FastFarmall
03-13-2019 17:48:42
 Re: farmall 300 hydraulic in reply to Larry Jensen, 03-13-2019 16:00:32
That's the factory tank,if your worried,it wont prime, put some air pressure to it,at start up !
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
