Company Logo Shop Now
TractorLinks.com
Order Farmall Cub Parts Online
Starter switch sticks on 49 farmall cub
Satohbill
03-13-2019 13:40:46
I put a new starter switch on my 49 cub still 6volt and it hangs. When I pull the rod to start the tractor the starter keeps spinning and then the starter starts to smoke. I have to pull the battery cable to stop it.
BarnyardEngineering
03-14-2019 06:08:03
 Re: Starter switch sticks on 49 farmall cub in reply to Satohbill, 03-13-2019 13:40:46
How are you getting it unstuck?
Unfortunately, the advice to take it back and get a "better" one is a waste of time. They're all made in the same factory, on the same assembly line, whether you get a cheap one off ebay, or pay the long buck for the one in the fancy NAPA box. Same exact switch, Made in China.
When you go to install make sure the nub on the starter is clean and smooth as you can get it. Make sure the switch operates smoothly before you install it. Make sure the rod doesn't bind. Pull the rod like you mean it. Don't "limp wrist" it because that causes arcing, and arcing can cause the contacts to weld together.
Satohbill
03-13-2019 17:34:54
So should I put any kind of contact grease or anything on the contact points when I put new switch on?]
gene bender
03-13-2019 18:29:37
 Re: Starter switch sticks on 49 farmall cub in reply to Satohbill, 03-13-2019 17:34:54
no just make sure the pull rod doesent bind
gene bender
03-13-2019 14:42:54
Are you sure the sw is sticking or the pull rod is hanging up and not returning back. Just unhook the rod and pull the lever to see if the sw pops back up as the pull rod can hang up
old
03-13-2019 14:20:54
Sounds like a switch from the land of NEVER right. If you got it at TSC take it back then go to a auto parts store or tractor dealer and get a good one
kl in wi
03-13-2019 14:15:54
Take the switch back and get a different one.
1946 BN IHC
03-15-2019 13:02:41
 Re: Starter switch sticks on 49 farmall cub in reply to kl in wi, 03-13-2019 14:15:54
I like the word remove the rod and work the leaver by itself. Even take the unit off the starter, work it by itself. If binding take apart, file, smothe down, etc, to make the lever operate smoothly. Personally, I eliminated the manuel starter switch, installed a brass bolt instead of the striker pad, hooked up a solenoid, and installed a key. This makes a safety setup so no one can accidentally start the tractor.
Wm.
1946 BN IHC
03-15-2019 13:02:17
Wm.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
