Hey everyone. Hoping you can help me out here. I'm jist about done with replacing the Bull Pinion Seals, and put fluid in today. I was about to get about 10 gallons in the transmission, and when I went to put fluid in the hydraulics, I wasn't able to get even 5 gallons in before it over flowed. No what I was expecting. I figured it would suck down, as I had some of the lines off and everything empty. I started it up, and the 3 point was able to raise, but I have to push it down. (Is this normal?) My other issue I have no loader pressure. The loader is a 1501, and has a pipe coming out the front of the tub (see picture). It would seem likely that there may not be enough fluid in yet, but I am very unsure of the priper level, since there is a stack up of fittings at the fill port. I currently have the level to the bottom of what seems to be a tube (about 3 inches down inside the tub itself) at the fill port. I've tried the On/Off knob in both positions and the red lever valve in the pic below in both positions, as well. Any help would be appreciated.
