Farmall Regular/F20 PTO extension
Been recently re-assembling my Farmall and decided to add as many accessories I can to it. I bought a PTO extension and found out it only fits F20's. I have read that there is a way to modify an F-20 style to fit a Regular. Could someone share?
Brad Regulars were not drilled underneath for the bolts holes. So two L shaped brackets were added to the top and bolts lined up with rear pinon cover bolts and that held it in place. Sorry I don't have a picture. But you may fine it on google.
yes like oldiron said. you can make them. sorry I have one but can't seem to post pictures right now. if you can set or hold it up under the rear end you probably can fabricate or I could e-mail you a picture if your not in a hurry. Rick (e-mail will work for pics)
I found this online, unless some one has a set guess I'll make some from strap iron. thinking my drive shaft extension will be to short but that's another thought I guess
Pretty positive that is a picture of our Regular... that I posted to show someone what the Regular PTO standardizer brackets look like. LOL
If you ever want dimensions to build replicas, could measurements for you... but first a mountain of snow has to melt away.
You will be lucky if you find them. More than likely you will have to make brackets. I have one on F20 and thought pto shaft was short but after I put an over running clutch on it sticks out past guard. I couldn't find guard and used one from newer tractor.
