Author |
[Modern View] |
OldFarmall450
03-11-2019 08:52:34
I have my dad's old drag type disk, but its badly worn, disks are paper thin, and its a pain to move from field to field. We pulled it with a JD A with no problems.
I'm looking at a JD RWA 12', the owner said my 450 should handle it with ease. What's the Max size disk/harrow my 450 can pull without pulling her guts out? I guess it may come down to getting it thru my gates, so 12' may be all I can handle.
Wanted other's opinion.
Thanks
DR. EVIL
03-13-2019 05:49:27
Re: 450 Gas, what size disk harrow can she pull? in reply to OldFarmall450, 03-11-2019 08:52:34
WOW! I wonder how much actual seat time some of you guys actually have that are making comments! A 450 gas only pulling a 7-8 ft disk and having to shallow it up in plowed ground? We're discussing a 450, Not an H! Dad pulled a 12 ft 4 inch Kewanee disk with 20 inch ripple blades, we used M&W direct axle duals any time we drove on plowed/tilled ground. I could run 3rd gear even up some fairly steep hills, with the disk as deep as it would go in plowed ground. In old corn ground disking ahead of plowing I could run in 4th gear in our more level fields, depending on temperature the engine would warm up pulling that hard, then I'd drop back into 3rd. I wouldn't go over 14 ft. And ANYTHING other than a Deere disk. Something around 12 ft would be perfect. Dad bought a Super M-TA about 1960, got carried away and bought a 14 ft Krause disk, just a bit too much disk, not enough tractor, the M&W duals were bought to try to pull that disk better. The SM-TA did much better than the JD R diesel did pulling that disk. Creep along in 3rd gear almost a mile per hour slower than the SM-TA.
The tractor vet
03-12-2019 09:11:18
When i had my 450 D i pulled a 13,6 370 with 20 inch blades with no problem , but when i went with duals it pulled a lot easier and a gear higher . Pulled the same disc with my S/MTA in third.
d beatty
03-11-2019 21:17:16
I have the same disk and the 450 will handle it ok.
OldFarmall450
03-11-2019 18:55:35
[quote="OldFarmall450"](reply to post at 18:54:09 03/11/19) [/quote
I know its WAY more tractor than I need, but its what I ended up with.
OldFarmall450
03-11-2019 18:54:09
I have about 20 acres of sandy loam that hasn't seen a plow in 25 years. We used to row-crop it. I was thinking about running the disk over it to cut the weeds, then plow it with 4 bottom moldboard, then disk it and drag it down. Gonna dryland row crop a bit see how it does.
rustred
03-11-2019 19:00:36
Re: 450 Gas, what size disk harrow can she pull? in reply to OldFarmall450, 03-11-2019 18:54:09
I would just plow it, forget the discing. it will just make for harder plowing and poorer job. if weeds are that tall cut them down with mower or swather. if you will be using a 12 ft. disc you probably need it lifted a bit, nothing saying you have to be buried to the spools. then harrow it down.
rustred
03-11-2019 17:18:08
makes a big difference on what gear you plan on pulling in. either 2nd or 3rd. plus plowed ground will pull twice as hard as stubble field. you didn't give any info on your field work plans. it basically a 10-12 ft disc tractor. go on stubble field and you will pull 16 ft!.
OldFarmall450
03-11-2019 16:27:42
I have 2 doughnut weights on each axle, can add more if needed.
FastFarmall
03-11-2019 17:03:49
Re: 450 Gas, what size disk harrow can she pull? in reply to OldFarmall450, 03-11-2019 16:27:42
If your goal is to replace the fluid weight with cast iron, you will need more cast iron,I have 6 set's on my tractors after i took the fluid out!
farmhand
03-11-2019 16:22:51
I pull a 13'FT with my Super M all day with the wheels racked up, should be no problem.
Bob M
03-11-2019 15:27:42
As a kid I disked literally thousands of acres with a Super M pulling a 12' Oliver disk. Made the tractor snort, but it got the job done. As others mention you will likely have the best results with duals (we did).
OldFarmall450
03-11-2019 13:13:32
Delta, you are right..its a small patch now, hoping to lease some one day.
DeltaRed
03-11-2019 11:13:06
12 ft. Maybe 14 in places,but duals would probably be needed. If gates ae an issue,stay with 12.another fact,better to have an implement 'too small' than to have one too big. You can always gear up and throttle down if needed.12 ft will be fine,I'll bet you're not farming a lot of acres either.If it were me,12 is as big as I'd want.
brownie450
03-11-2019 11:01:06
Nothing against JD discs, but I wouldn't have one on the place. The neighbor had a JD & you could see ridges all summer long---never could get the ridges worked out. We pulled a #37 disc with our 450D----14 footer & it never had any trouble. When you left the field, it was flat--level. Jim
ed12345
03-11-2019 14:54:55
Re: 450 Gas, what size disk harrow can she pull? in reply to brownie450, 03-11-2019 11:01:06
JD letter series discs are terrible They leave ridges all year and tow like crap swinging back and fourth across the road. You need an 7 or 8 ft IH # 37 Sure you can pull a 14 inch disk on rock hard ground but if plowed you’ll have it raised up barely touching The 7 or 8 footer is all it can handle
FastFarmall
03-11-2019 10:17:16
I would say a 14,foot a 47 or 470 IHC Disk, and a harrow behind that, should work,that's what i pull with the M's and super MTA.
FastFarmall
03-11-2019 14:33:56
Re: 450 Gas, what size disk harrow can she pull? in reply to FastFarmall, 03-11-2019 10:17:16
And i have 10 John Deere, 100# front suit case weight's on the back of the disk, after the wheat was off i would go thru the slough's or low area and disk it up!
ss55
03-11-2019 10:04:44
WayneLee
03-11-2019 10:00:02
450 will pull that easily.
Denny ('60 Lo-Boy)
03-11-2019 08:59:39
Should be no problem. Super M's can pull them all day long.
TomA
03-12-2019 08:28:14
Re: 450 Gas, what size disk harrow can she pull? in reply to Denny ('60 Lo-Boy), 03-11-2019 08:59:39
You guys must be talking about a tandem disk. An offset is a different story, right?
farmallhal
03-12-2019 19:55:29
Re: 450 Gas, what size disk harrow can she pull? in reply to TomA, 03-12-2019 08:28:14
I'm sure either a single or tandem model as an offset disc would require to total different thread, Hal.
