Hydraulic pump
BHpony
How do I tell which Hydraulic pump is on farmall 200. I don't see Thompson or Pesco name on pump. Where is a good place to buy rebuild kit. Thanks.
replace the seal and if the shaft is worn use a speedy sleeve so the seal stops getting hy fluid into the engine outside of that replace the pump no rebuild
yes to what mr bender said. clean the shaft, where the seal goes, until really slick. put new seal on it and replace. 30 wt non detergent motor oil also helps. seal , by itself, may be a bit hard to find.
chuck the shaft into a drill, and spin it and use fine sand paper to clean up
