SadFarmall
I found a a shop to repair the temperature gauge for my 1937 F12. Sent it off on Monday and it came back today (Friday). They replaced the capillary tube and bulb and repaired the seized mechanism. As the F12 temperature gauge operates from the bottom of the radiator, it reaches full scale deflection well before water boiling point. Ignoring the parallax error, accounted for by its location on the tractor, it reads as follows:
The temperatures are adjusted to the nearest 5 as the measurements were taken in degrees Celsius.
70F needle just to left of O on COLD
80F needle just inside left of O on COLD
85F needle a little further inside O on COLD
95F needle at centre of O on COLD
105F needle just inside right of O on COLD
115F needle just to right of O on COLD
120F needle just to left of D on COLD
130F needle between D on COLD and R on RUN
140 F needle on right side of R on RUN
150F needle on left side of N on RUN
155F needle on right side of N on RUN
160F needle at end of green section
165F needle on right side of H on HOT
170F needle on left of O on HOT
175F needle on right of O on HOT
185F needle on stem of T on HOT
If anyone has a temperature gauge for sale, working or not, I would be happy to purchase one for the second F12, which will be worked on over the course of this year.
SadFarmall
SadFarmall
