SadFarmall
I found this photograph of a Farmall H, showing the Ammeter. As can be seen, it also shows various other features, which I have not seen on a Farmall H.
1. Light switch - long lever
2. Fuel Sediment Bowl looks to be under the starting tank, not the main fuel tank.
3. Starter button - same as on my Farmall M tractors (not pleasant to push unless you have thick soled boots on your feet).
4. Gear shifter has no bend at all.
5. Rubber gear shift knob a different shape from ones I have seen.
Are these early designs, which were changed in production, or possibly seen on prototypes for IHC?
SadFarmall
SadFarmall
