engine swap
povertyknob
03-07-2019 10:33:13
I've wondered with all the IH wizards on here, has anyone swapped a 450 C281 into a 560? I know it would be a huge project and a lot of things would have to be changed/fabricated mainly the fuel tank, because the 281 is a lot taller, I think itd be a neat conversion with the 560s features, power steering and hydraulics and tel a depth fast hitch.. I know also it doesn't take much to get a 281 to 560 power levels either along with its torque and reliability, might be a win.. Just daydreaming on a crappy snowy day, wishing spring would get here fast
BarnyardEngineering
03-08-2019 07:53:54
 Re: engine swap in reply to povertyknob, 03-07-2019 10:33:13
Pretty much the same challenges as the guy wanting to put a 350 engine in a 504.
Right off the bat it would bolt right up to the bell housing using the 450's rear adapter plate. I think the input shaft and IPTO drive would even line right up with the 450 clutch.
rustyfarmall
03-07-2019 14:50:10
I've been told that a Cummins 5.9 is a nice fit in a 560.
Camboted
03-09-2019 14:36:33
 Re: engine swap in reply to rustyfarmall, 03-07-2019 14:50:10
If you cab find a junked diesel 715 combine. That really works well.
FastFarmall
03-07-2019 14:05:59
Have you considered the 361 that's for sale in the classifieds, that would be my idea of a nice swap.Turn the rpm's down and you would be good to go!
ejr-Ia.
03-07-2019 11:06:46
The clutch housing same pattern will bolt up the rest not sure
povertyknob
03-07-2019 13:17:52
 Re: engine swap in reply to ejr-Ia., 03-07-2019 11:06:46
Exactly, it would bolt right up, in my mind the clutch and bell housing would be the hard part, I wonder too if the 450 fuel tank could be made to fit easier?
Dieseltech
03-07-2019 10:41:30
Keeping the 560 steering shaft where it belongs might be a problem with the 281..
povertyknob
03-07-2019 11:00:01
 Re: engine swap in reply to Dieseltech, 03-07-2019 10:41:30
Didn't say itd be easy hahahaha
Mikes806/h
03-07-2019 11:47:27
 Re: engine swap in reply to povertyknob, 03-07-2019 11:00:01
I have a farmall 460 with a farmall H rear end and bell housing, I"m sure the 450 engine in a 560 is possible,
