I rebuilt a BN I had and got it running. But I didn't have any clutch. That is, with the clutch pedal all the way down the fingers on the clutch were not being depressed enough to release the clutch plate. So, I adjusted the linkage in the torque tube as far as possible but the gears were still grinding to get into gear. I adjusted it a little more and it started a loud TAT-TAT-TAT from the clutch. So my question is this. Can I not switch out a clutch from an A to the BN? Because that is what I did thinking they were interchangeable. I guess not. So, I wanted to hear from you guys before I break this thing into to see what the problem might be. I did replace the throw-out bearing I might add.
